General LSX Automobile Discussion Non-technical LSX related topics.
need help with t top seal part number
Old 01-20-2010, 05:32 PM
ssjason232's Avatar
Default need help with t top seal part number
I was looking at the t bar where the t tops slide in today, and on the front and rear of the actual t bar, there are two small seals that go around the inner corners of the t tops. mine are crushed and im sure are bound to leak at some point.
I went to the dealer today and had them pull the diagram but they arent on the diagram. WTF.
anyone know the gm part number so i can order a set?
thanks
Old 01-30-2010, 10:42 AM
mikey1107's Avatar
[QUOTE=ssjason232;12777376]I was looking at the t bar where the t tops slide in today, and on the front and rear of the actual t bar, there are two small seals that go around the inner corners of the t tops. mine are crushed and im sure are bound to leak at some point.
thanks[/QUOTE
What year and model is it?
I will try and help.
Old 01-30-2010, 10:49 AM
slayerized6's Avatar
http://www.hawksthirdgenparts.com/t-...ponents_4.aspx
Old 02-02-2010, 05:12 PM
ssjason232's Avatar
thanks for the link, but that diagram is waaay to small to make any sense. Ill go to the dealer at the end of the week when i get back in town and have my friend there pull up that diagram. ill post the results if i can get any.
ssjason232's Avatar
oh, to your question, 99 Z28, camaro.
Old 02-02-2010, 05:24 PM
Lotus289's Avatar
Front Seal: 10248550
Rear Seal: 10248551
The dealer only sells them in bags of 10 for around $1 each.
You're Welcome!
*EDIT*
After re-reading your original post, you're talking about the little rubber seals that slide into the front and back of the center bar correct? If so, those going bad won't cause any leaks, they're purely cosmetic.
Here's a pic from the GM Parts Manual. Part #3 is the center bar, but the seals aren't pictured.
Old 02-06-2010, 11:51 AM
ssjason232's Avatar
kick ***, your the man. thanks for posting that up. I saw that pic at the dealer, but we couldnt find the seals on it. Ill order a set as soon as the 30+ inches of snow we just got melts away.
thanks again.
Old 02-06-2010, 06:25 PM
Lotus289's Avatar
Yeah no problem.
Old 02-06-2010, 06:33 PM
APG12's Avatar
if you go to gmpartsdirect.com and type in those part numbers you can order them individually for about 68 cents
Old 02-06-2010, 06:34 PM
Lotus289's Avatar
Yeah you can, but you're gonna pay $15 for shipping! no joke. it's actually cheaper to get them from the dealer.
Old 02-06-2010, 06:36 PM
APG12's Avatar
damn yea good call i didnt even think about that
