need help on new engine build!!!
i have a 6.0l bored .030 over, flat top pistons (stock stroke) with 5.3l heads ported and polished milled .060 and im having problems breaking springs. i have comp 7.4 pushrods and i think theyre the wrong size. can anyone help me out? also whats the compression ratio on the engine with this setup? thanks
Ummm you mean you have 4.00 pistons in a 4.030 bore?? Get a PR checker cause those PR's are too long milled .060. Is the valvetrain noisy? I am pretty sure you are are bottoming out the plunger on the lifters and they will soon fail too. Also check the spring installed height....
What cam specs and springs????
