SLP vs Magnaflow
I got the timeslips to prove the change makes a difference! I had my lm2 exhaust installed last year. I didnt like the loud sound from the lm2 with my h/c package. I ordered a magnaflow bullet, but decided to get a before and after timeslip test. With the lm2 I ran a best of 12.35. With the only change being the magnaflow bullet install I went back to the track and my first pass was a 12.05 and after cooling it ran 12.03! The magnaflow was much quieter and I was surprised with the faster et!
__________________
__________________
It was the next day and the temps were very close. There were no other changes to the car but the magnaflow! I was one of the first cars down the track, so I had the benefit of a fresh sticky track.
Actually, no. The SLP sounded way better when getting on it and even just acclerating lightly. The magnaflow has a much deeper tone. Reminds me of GTO exhaust for some reason.
The reason I switched is due to how loud it was. I could never hold a conversation with the SLP. With the magnaflow, I can finally hear people.
Do you have a dyno chart for both? I'm not saying it is faster, but that it feels faster. I'm guessing it due to better torque down low.
Ex. I have a 71 Nova that had a 454 in it. It felt fast, but lost its *** on the top end. I could out accelerate an F-body up to about 40-50, but lost ground after that.
IDK these systems might dyno different numbers on different cars with different setups on different days, but I have seen dyno sheets and both systems dyno with 5-10 HP of each other on "similar" setups. Ive always heard that every 10 HP is roughly .1 off of 1/4 mile times. So if someone saw .2-.3 difference with JUST the switch of these catbacks that would mean that there is 20-30 HP difference between them And I just find that hard to believe, when ive had both of these catbacks on similar cars with the same results
My point is that there both good catbacks and there are ALWAYS going to be a few cases saying one is a ton better then the other... http://www.camaroz28.com/forums/show....php?p=2955731
Theres a thread saying that LM makes 13hp/25 tq more then magnaflow same car same dyno. If there was that much different one of the systems would have a flowmaster reputation, opposed to the general consensus that you should get whatever sound you like better b/c the performance is comparable
i think the gain in quarter mile times may be due to a change in the power band, not necessarily a huge change in peak HP. there may just be slightly more power consistently through the rpm range.
#33
i have slp lm1 on my 01 ss and wouldnt trade it for the world i think it can be loud at times but its easy to keep it quiet its called keep your foot out of it. But i think it pulls more air threw than the magnaflow cause i have the magna flow on my 02 ws6.
#34
Do you have LTs and ory?
#35
EDIT: I also have an in-car video with the LTs, ORY, and XR1 going down the track, one outside the car, and one of the dyno if anyone is interested.
#36
I had a loudmouth and when I went to LTs, I never even started in on the LM. I put a Borla XR1 muffler directly in place of the LM expanded-piece-of-pipe. I absolutely LOOOOOVE the sound. I kept my sweet LM tips and anywhere below 3k, it's just a beautiful grumble, as soon as you put your foot in it, it is screaming. Very quiet idle and very loud WOT. For what I paid, it can't be beat. I'm convinced.
#37
I did end up ditching my magnaflow for TSP Duals with bullets dumped.. and it is everything i wanted. The magnaflow is just too quiet. The duals sound is perfect. Definitely sounds more powerful with true duals.
#38
For me i just like the sound of the Magnaflow, my son had SLP on his SS way to loud for me i had the Magnaflow on my 99 SS and currently on my 03 Z06 I like the lower tone for me personally, did i gain over my corsa or borla, thats i qestion i cant answer but, what ever floats your boat , and what u like is the answer your looking for, based on that u can't go wrong
