ls1 help please
ok i just did a 98 trans am swap to a 93 camaro everything went good everything works fine butttt.... now the car wont keep running the speedo doesnt work only the volt meter thats normal. i dont have all the o2 sensors hooked up yet i bypassed the fuel pump relay because i couldnt get the fuel enable to work so i just found out wen i bypassed the vats pellet wires with the resistor i found out that the car turns over and starts for 3 seconds about and shuts off with the resistor hooked up or unhooked and now im totally lost i dont know where to start figuring this out im in desperate need for some help everything looks like it should be fuses are all good so far i dont have the plug for the inside of the air box cant remember what its called i need some help anything is possible please help.....if this is in the wrong place to post sorry lead me in the right direction please thanks
Last edited by schottracer; 04-23-2010 at 12:23 PM. Reason: if post is in the wrong place
