New F body
2002 F/B Forumla A4, only mod is corsa cat back.
Three runs 13.7, 13.71, 13.716, all 60 ft times were just over 2.06. MPH is 103 every time.
I left at 2K RPM for each launch.
Now I have the baseline, I have some go fast parts, but need to know if I can really make this a 10.5 daily driver.
Car has 72K miles.
I have Tubular suspension for front and rear, I know the front will save some serious weight and the rear will get rid of wheel hop, but after that should I put N20 or STS. Alos have longtubes, and can do heads, intake and cam. Have to keep A/C as I live in St Louis, MO.
What will a stahl do to my driveability and I want to keep the current gears, unless I swapp to a 6L80. Or should I just swap in a ls3 to start.
Any input would be appreciated.
FORMULA!!Guys correct me if I'm wrong!!
The easiest way to a 10.5 DD car is a H/C/I with a little giggle juice. You can do it on a stock bottom but forged will be almost bulletproof and the way to go if it is in your budget.... BTW what is your budget.... I have a friend running budget heads & 90/90 full boltons 383 running high 10's no no2. Better heads and he would be right where youwant to be. This is a full weight car with not even the jack removed.....
