cam swap ?
cam swap ?
hi all..im new to the forums as well as the ls1 world..ive had my trans am 3 weeks and i bought a ms4 cam...im in the process of acquiring all my parts to make the swap possible..my question is...to the guys that have done the "pen magnet" gig to suspend the lifters so you dont havta pull the heads/intake..how are you securing the magnets to the engine so theyll keep the lifters lifted?...thanks in advance...
I used wooden dowls and it was cheaper than pen magnets and it worked perfect.
I actually got the idea from a online Cam Swap guide for LS engines.
Anyhow, it was two 5/16 or 1/4" wooden dowels 26" in length. I used 5/16.
I picked em up at a local crafs store, but HD or Lowes would have em
After you remove the WP, Timing Cover and the Cam Retaining Plate, and spin the cam a few times to knock all the lifters up and away from it (removal of rocker arms and PRs required)
then there are 2 holes the Cam plate was covering that you can slide the dowels into and if a lifter happens to drop it will just bump into the dowl and not drop into the oil pan.
Idea worked great for me.
http://konrademrich.com/cars/gto/ls1gtocaminstall.doc
He is working on a Goat, but its still an LS and has great ideas.
Good luck.
--Glenn
Good luck.
--Glenn
