General LSX Automobile Discussion Non-technical LSX related topics.
Old Apr 25, 2016, 04:03 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Air Intake and Exhaust Guides
Print Wikipost
LS1 headers
Old Jul 9, 2010 | 08:52 PM
rampage01ss's Avatar
Default LS1 headers
im planning on getting some headers for my ls1 camaro. wanted to know what size headers would be the best ones to get. 1 3/4 or 1 7/8. or i heard that 1 3/4 stepped to 1 7/8 was better. and does brand really matter. im looking to spend around 600-500 bucks. Thanks
Old Jul 9, 2010 | 09:39 PM
*02WS6TURK*'s Avatar
If you plan on building the motor in the future then go with a 1 7/8 header. If not and you are just going to do the basic bolt ons, then the 1 3/4 are just fine. The Kooks and American Racing are two of the best brands avail. Best bang for the buck would be some ceramic coated Pacesetters. I picked my Pacesetters up from Texas Speed for roughly $550 w/ the Y-Pipe.
Old Jul 11, 2010 | 04:20 PM
ULTIMATEORANGESS's Avatar
ARH. save up and get the best.
Old Jul 11, 2010 | 04:24 PM
Zmg00camaross's Avatar
With That budget. i would look at the Texas speed 1 7/8 headers. Fit fine with poly mounts installed
Old Jul 11, 2010 | 04:38 PM
Camaro_94's Avatar
Pasesetters are the best bang for the buck headers out. I had them on both my F-bodies.. They fit good, are real reasonably priced, and provide a nice power gain.
Old Jul 11, 2010 | 06:29 PM
johnpate01's Avatar
I will have to vouch for pacesetters. Outstanding for the price and they fit right. I got the ceramic coated ones about 5 years ago for absolutely dirt cheap (~$350 with a y-pipe). They are just now starting to rust on the driver side collector. Can't beat that.
Old Jul 11, 2010 | 06:49 PM
01SuperSport's Avatar
I like my pacesetters
Old Jul 11, 2010 | 07:43 PM
ds98formula's Avatar
Love my Ebay header Stainless steel and only 190 shipped to my door
Old Jul 11, 2010 | 11:45 PM
Badguy7's Avatar
You've got quite a few options in the price range your looking at. So ill give you 1 more, you can get ceramic coated BBK longtubes & Off-Road Y pipe for $499 shipped from LMPerformance.com or you can go the cheaper route and get the Chrome finished ones.
They fit great, good ground clearance with the y pipe and before anyone mentions it. Yes, the Y-Pipe BBK offers is 2.5" then merges to 3". I really doubt it'll make much of a difference if it was all 3". Unless your concerned with HP numbers.
Old Jul 11, 2010 | 11:58 PM
1993 z28 f1's Avatar
Hey:
Buy some LPPs or LSXtreme, check out ebay for some good prices on these.
Dub
Old Jul 11, 2010 | 11:59 PM
PadenAlbin's Avatar
Pacesetters! Shipped 430 bucks and coated. If your looking to spend 600 bucks buy some pacesetters and you'll have enough for plugs n' wires and motor mounts to install along with your headers.
Old Jul 12, 2010 | 12:18 AM
Z28_LT1's Avatar
What are your realistic plans for the car? 1 3/4 is fine for most street applications. I'd go with the 7/8 if you're going to be making a good amount of power down the road.
Old Jul 12, 2010 | 12:47 AM
99SSJarhead's Avatar
couple things to look for.
First get under you car and check out how your current exhaust is put together. Mine is welded from the stock manifold flange all the way back. Everything from the I-pipe to my LM1 resonators. This means I'd have to look at removing the entire system out to the tips (luckily I am doing true duals so it was going anyways). This will add to your build if you have to replace your current I pipe backwards as well as just the headers and new Y.
As others have said, 1 3/4" is good for bolt-ons. When you get around 450hp it may do well to step up to 1 7/8" (or start there if you plan on putting a lot of money into your build), and over 500hp move on to 2".
Then remember to factor in o2 sensor extensions. Mine for some reason already had one on the driver side.
You may as well needs to replace your gasket. Some have luck re-using, others not so much.
Depending on who you buy from, you may as wellhave to factor in clamps into your build as well.
Old Jul 14, 2010 | 11:47 AM
jlasserton's Avatar
eBay is a great idea. I would also save my money for the best one. It will be worth it in the end. I am a big fan of LSXtreme, so I would look online for what would be best for you in the long run.
Old Jul 14, 2010 | 11:50 AM
DanasixT's Avatar
Do yourself a favor and dont buy pace setter. You will be replacing them down the road. Do it right the first time. Realistically, a good stainless header isnt that far off. 1-7/8" would also be my choice, especially if plan on any power down the road.
Old Jul 27, 2010 | 06:22 PM
Default thanks
well thanks alot guys...i am planning on putting on some heads and cam later down the road. so im prob gonna save a little more money and go for the 1-7/8 headers.
Old Jul 27, 2010 | 06:26 PM
TXZ28LS1's Avatar
if you havent purchased headers yet, i would highly consider TSP 1 7/8 headers.. i think they are about 600 bucks.
Old Jul 27, 2010 | 06:43 PM
Mine were 530 shipped
Old Jul 27, 2010 | 07:13 PM
608kZ28's Avatar
i vote for pacesetters as well. install wasnt hard. the hardest part was the exhaust manifolds coming off. mostly breaking the bolts holding them in
