compression question
i just picked up a lq9 short block. stock bottom end. i also got a set of tea stage 3 5.3 heads. 63cc stock but these were milled .020. my question is, what will my compression ratio be and also what would you say the max lift cam i can use with out fly cutting the pistons?
http://www.race-cars.net/calculators...alculator.html
LQ4= dished piston 9.4-1 CR
he is running 5.3 heads milled i think it has 61cc do the math bore 4.000 stroke 3.662 flat pistons Gasket Thickness let say .048 it comes to 11.63:1
