Factory alarm goes off at random
Two days in a row now the horn on my 2001 Z28 has just gone off for no reason. It's in my backyard so it hasn't been messed with or hit.
I searched on this topic and found rain or moisture might be the problem, but the car hasn't seen water in months at least.
While searching I found that the shock sensor can just be disconnected.
Is disconnecting the shock sensor a permanent solution? This won't effect anything else?
You can disconnect the shock sensor and not effect anything else. I had the same problem, but mine would go off like every 10 mins. The alarm will still go off if someone tries to start the car or break in.
Trunion King
I'm not saying its your the problem however it could be the possibility. Go take off your alarm sensor out, unplug and take it part. When I took mine apart, the contacts in the circuit were all corroded from the moisture from the previous rain/wash and humidity. I cleaned them up, alcohol/Qtip and put them together, sealed them tight w/ electrical tape and it works again like it supposed to w/o the random alarm going off.
