New motor lacks oil pressure
I'll make this short and sweet. 2002 Z06 with a 406 LS2 Stroker transplant with modified LS2 pump and stock LS6 heads/intake/TB. I just got the motor to crank but since it's so late and I dont plan on moving out of my neighborhood anytime soon I have to wait till tomorrow for breakin. After about 6 few second cranks i'm only noticing the oil pressure gauge flutter a little at 0 psi. It makes since to me that it will take a little while for the oil pressure to build up to where the sensor is but I wanted to check with everyone first before I go ahead with running it longer. Oh, I forgot to mention it is running the STS twins in the back and has to pump the 1/2 oil lines back there from the pressure stem right above the filter.
With the pump being mechanical I dont see how the pressure could be inexistent for very long but I have heard of some strange situations of it cloging with build lube. And yes the sensor is plugged in.
Thanks for the advice and your own experiences.
-Brandon
-Brandon
