VIN Question/Problem
I am looking to get a Trailblazer SS as a winter vehicle and need some help from either a "VIN Expert" or a GM Guy. I run the VIN through carfax, getthevin.com, etc and get the same thing -
"NO records for this vehicle"
Has anyone ever heard of this?
The vehicle is a used 2007 Trailblazer with 30k on it. It should have at least a record of sale or titling right? How does it say no records? Can you erase a vehicle history? I am so confused about this, anyways, here is the VIN, just curious what somebody can dig up or let me know their opinion is. Thank you very much.
1GNET13H972277661
The VIN does say in Carfax it is a 2007 Trailblazer SS AWD, but I am so weirded out by this...
http://www.compnine.com/vid.php
Try any other GM VIN and you get the SPID codes, etc.
1GNET13H972277613
Last two digits are different, and I know this vehicle was involved in a wreck. I was just trying to confirm the person didn't make like one good vehicle out of two or swap vins or something like that.
Anybody with GM hook ups be able to give me the RPO Codes and options that came to see if they match up? I appreciate any help, thanks to the above two posts as well.
EDIT - Just did it on the compnine site. Thanks!
VIN: 1GNET13H972277613 Model: CT15506-2007 TRAILBLAZER 4WD
Service Contract: No Branded Title: Yes Warranty Block: Yes PDI Status: No
Order Type: 70 - RETAIL - STOCK
Field Actions: 0 Open
Vehicle Build
Model: CT15506-2007 TRAILBLAZER 4WD Order Number: KWJG66
Gross Vehicle Weight: 2,724 Build Date: 05/07/2007
Build Plant: 2-
Option Codes
*GMVIS is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
1SZ - PREFERRED EQUIPMENT SAVINGS 3SS - SS PREFERRED EQUIPMENT GROUP 3
41U - BLACK 482 - EBONY
48I - INT TRIM EBONY/EBONY 6XK - COMP FRT LH COMPUTER SEL SUSP
7XK - COMPONENT FRT RH COMP. SEL SUSP 8BZ - SUSPENSION COMPONENT
9BZ - SUSPENSION COMPONENT AAB - MEMORY DRIVER CONVENIENCE PKG
AJ1 - GLASS, DEEP TINTED AK5 - DUAL STAGE FRONT AIR BAGS
AL0 - SENSOR INF RESTR, CHILD DETECT AM9 - 65/35 FOLDING 2ND ROW SEAT
AR9 - FRT BUCKET SEAT, DELUXE ASF - HEAD CURTAIN SIDE AIRBAGS FRONT/REAR
AT8 - RESTRAINT PROVISIONS CHILD, RR SEAT, RR FACING AU0 - REMOTE KEYLESS ENTRY
AXP - MPV VIN IDENT POSITION B30 - FULL CARPET-COLOR KEYED
B32 - FLOOR MATS, FRONT/REAR B33 - REAR COLOR KEYED FLOOR MATS
B42 - REVERSIBLE CARGO MAT B4U - TRAILBLAZER SS
C49 - REAR WINDOW DEFROSTER CF5 - POWER SUNROOF
CJ2 - AUTOMATIC CLIMATE CONTROL DAY - ASSEMBLY PLANT MORAINE, OHIO
DD7 - INSIDE REARVIEW MIRROR, AUTO DIMMING, COMPASS DH2 - LIGHTED LH & RH VISOR MIRRORS
DK7 - OVERHEAD CONSOLE DS3 - POWER OSRV MIRRORS, HEAT, TURN SIGNALS
EB1 - GVWR, 6001 LBS. EVA - EVAP EMISSION REQUIREMENT
FE9 - 50-STATE EMISSIONS G67 - AUTOMATIC LEVELING SUSPENSION
G86 - AXLE LIMITED SLIP GME - ORNAMENTATION, GM MARK OF EXCELLENCE
GT5 - REAR AXLE, 4.10 RATIO JF4 - POWER ADJUSTABLE PEDALS
JF8 - BRAKE VAC POWER, 4 WHL DISC JJB - PT DRESS SUBASSY NOT INSTALLED
K34 - CRUISE CONTROL KA1 - FRONT HEATED SEATS
KG3 - 145 AMP ALTERNATOR LS2 - ENGINE, 6.0L SFI V8
M70 - TRANSMISSION,4 SPD HD AUTOMATIC N40 - POWER STEERING
N79 - 17" FULL-SIZE SPARE WHEEL NR9 - TRANSFER CASE ALL WHEEL DRIVE
NT8 - EMISSIONS, FED TIER 2A P55 - 20" POLISHED WHEELS
PCR - SUN, SOUND, ENTERTAINMENT PKG: * POWER SUNROOF * AUDIO SYSTEM-BOSE PREM. SOUND * AM/FM STEREO W/6 DISC CD PLAYER, AUTOTONE CONTROL, RADIO DATA SYSTEM (REPLACES STD/OPT PKG RADIO) PDC - PWR SEAT ADJUST-DRIVER, 8 WAY
QUB - P255/50R20 TIRES R6K - ONSTAR TURN-BY-TURN NAVIG AVAIL
R6P - SPECIAL PAINT R9L - SPRING WHOLESALE FLOORPLAN PLUS
R9N - LEATHER SEAT TRIM R9X - XM RADIO STANDARD IDENTIFER
SLM - STOCK ORDERS STW - LEATHER WRAPPED STG WHL W/CONTR
T61 - DAYTIME RUNNING LIGHTS T96 - FOG LAMPS
T98 - STAMPING VEHICLE IDENT NUMBER TB4 - LIFTGATE
TGA - LANGUAGE CONTROL ENG, FR, SPAN U2K - XM SATELLITE RADIO - SERVICE FEE EXTRA. 1ST 3 MONTHS INCL.
U68 - DRIVER INFO CENTER DISPLAY U73 - FIXED MAST ANTENNA
UA6 - THEFT DETERRENT ALARM SYSTEM UCB - WIRING HARNESS
UE1 - 1 YR ONSTAR SAFE & SOUND (ASK DLR ABOUT TURN-BY-TURN UPGRADE) UG1 - UNIVERSAL HOME REMOTE
UJ6 - TIRE PRESSURE MONITOR UK6 - REAR SEAT RADIO & HVAC CONTROLS
UM8 - NAVIGATION SYSTEM INCLUDES TWO FREE MAP UPDATES (REPLACES 6 DISC CD PLAYER) UQA - AUDIO SYSTEM-BOSE PREM. SOUND
V40 - PWR SEAT ADJ-PASSENGER, 8 WAY POWER LUMBAR, FRONT PASSENGER V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
VK3 - FRONT LICENSE PLATE BRACKET VXS - COMPLETE VEHICLE LABEL
X88 - CHEVROLET CONVERSION YC6 - LT PACKAGE 2 * MEMORY: DRV SEAT,OSRV MIRROR * OSRV MIRRORS W/TURN SIGNAL * HEATED FRONT SEATS * ETR AM/FM STEREO W/CASS., CD RDS, THEFT DETERRENT (REPLACES STD/OPT PKG RADIO)
YD3 - BASE AXLE YD5 - BASE FRONT SPRING
YD6 - BASE REAR SPRING ZQ3 - DRIVER CONVENIENCE PACKAGE: DRVR MESSAGE CNTR, AUTO CLIMATE CONTROL, RR SEAT RADIO AND HVAC CTRLS. LEATHER STRG WHL W/CONTL
ZQ8 - SPORT HANDLING PACKAGE ZTM - SPARE, ALL-SEASON TIRE
ZY1 - SOLID PAINT
GM VIS shows only work done at a GM dealer is the Pre delivery inspection.
