General LSX Automobile Discussion Non-technical LSX related topics.
stroker kits...
Old Jan 11, 2011 | 12:58 PM
westboundmack's Avatar
Default stroker kits...
whats everybody's opinion on stroker kits? yay or nay? pros and cons? heard that they don't make a 383 kit for LS motors, only start at 408, is this true?
Old Jan 11, 2011 | 01:53 PM
98TAjwh's Avatar
check out texas speed. they have a bunch of different kits
Old Jan 11, 2011 | 03:10 PM
SOMbitch's Avatar
Well I am biased since I have a LS2 403 stroker
The 346 LS1 is most commonly stroked to 383cid. Tons of configurations when you look at all the LSx stuff. Go search internal and you will learn a lot....
Old Jan 11, 2011 | 03:58 PM
Benjamin Russick's Avatar
I had a 382 stroker in my previous 2000 Z28...it was a blast. The 402s are even better with the larger bore, but a well set-up 382 can make 500+rwhp and 480+rwtq. The broad/flat tq "curve" is way fun on the street...at the expense of tires.
Old Jan 11, 2011 | 04:00 PM
3.8redbird's Avatar
the 3.9 bore can be stroked to a 382 or 396 depending on a 4" or 4.1" stroke.
The 4.0 bore is where its at though because of better head choices.
Old Jan 11, 2011 | 04:25 PM
SOMbitch's Avatar
Hardly anybody does a 396 though because there can be issues with the piston coming so far out of the hole...
Old Jan 11, 2011 | 04:41 PM
N2OBaby's Avatar
Thumbs up
I have heard of 390's being built with the LQ4/9(6.0L) with a 4.03 bore & 3.825 stroke.
Others use the stock crank(3.622) and a 4.03 for a 370 cid non-stroker.
$$$ talks.
Old Jan 11, 2011 | 04:50 PM
3.8redbird's Avatar
Trust's old trans am is local to me. His 396 runs very well.
Old Jan 11, 2011 | 05:48 PM
SOMbitch's Avatar
I didn't say it couldn't be done I just said it was not common and why.....
Old Jan 23, 2011 | 08:02 AM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Funny.... I have Trust's old Ram Air hood.... Also curious about a 396 ls1
Old Jan 23, 2011 | 08:53 AM
Orange Juice's Avatar
When you push the stroke to the limits then you are pushing the limits of ring spacing on the pistons. You could have issues with oil consumption. Best that you talk to a reputable builder to keep you on track.
