need help 1998 trans am
if i put headers on is there anything i need to do speical when i put them on also has anyone lowered there trans am and do i need to anything with the spindles thanks rich
Headers, if they are long tubes (what I recommend) you will need a Y-pipe that matches. You will also need a tune to turn off the check engine light if you use a "off road" y-pipe (one that has no cats). As for lowering a good set of lowering springs and you are set. A adj panhard bar is nice when doing the alignment you will need to do afterwards but not neccessary.
1 Post
Wow, you are super new lol! Just like Sedanman said. ALso this site has some of the best info on any messageboard. To add to Sedanman a good set of shocks is pretty much needed because the stockers are garbage even on the stock springs
