General LSX Automobile Discussion Non-technical LSX related topics.
Cam Quest (software)
Old Mar 18, 2011 | 08:27 PM
bayer-z28's Avatar
Default Cam Quest (software)
Was looking through the LSXTV.com site and saw this advertised software. Registered and tried it out. Some of the cams are VERY mild and almost sock, But I DID stumble on one of their torque spec cams that actually looks pretty good at 223/231 .610/.617 112 LSA with a 3500lb vehicle weight.
Seems right on. It's got more duration than my PatG cam with LSk lobes, which leads me to believe that these lobes on this spec'd cam should be a little more kind to the valve train.
I saved a screen shot so you can see. Not trying to solicit, but the software is free and is a pretty good idea for those shopping around for cams.
Old Mar 21, 2011 | 01:25 AM
01ssreda4's Avatar
I downloaded it and plugged in my info. It gave me almost identical specs to the cam I already purchased from Cam Motion. **** was weird bc it was so close. I bought the cam based on someone on the board's recommendation. I only plugged the info into the program as a goof. Im happy with the cam, so yeah, I'd say its pretty accurate.
