General LSX Automobile Discussion Non-technical LSX related topics.
is this normal---pics inside
Old Mar 30, 2011 | 12:13 PM
ivan_key's Avatar
Default is this normal---pics inside
I'm just wondering if this is normal for my oil pressure with this age and mileage, seems to stay low even crusing around town, only goes to 40 or above when on the highway or I give it lots of gas, also goes a little lower sometimes
Attached Thumbnails is this normal---pics inside-gauges.jpg   is this normal---pics inside-sni-bar-20110330-00459.jpg
Old Mar 30, 2011 | 12:45 PM
Gordon0652's Avatar
To me that would be low. What oil are you running? With that kind of miles, you may need to replace the pump - not a big deal.
Old Mar 30, 2011 | 12:49 PM
ivan_key's Avatar
I'm running mobile 5000 5w30. I would hate to change the oil pump with out replacing other parts while I'm there like the cam ect.
Old Mar 30, 2011 | 12:51 PM
Z Fury's Avatar
Doesn't look low for 800 RPMs... Mine normally operates between the 20 and the 60, which I figure is good. Anything outside that range and I'll worry.
Old Mar 30, 2011 | 12:52 PM
blackodium's Avatar
stick to the basics my friend. just fix the broken
Old Mar 30, 2011 | 12:58 PM
ivan_key's Avatar
Ya I guess I may have to, not the first time I had to just fix the broken, my last t/a was a 98 with a 144k miles and bent a push rod and broke the lifter tray so the lifter spun and chewed the cam up, I had to replace the cam, lifters, trays and all gaskets with stock stuff, witch only took a day but sucks I couldn't upgrade at the time
Old Mar 30, 2011 | 01:03 PM
gringo dfw's Avatar
My oil pressure needle is pinged all the way to the left. then again its a V6 with more miles than moses through the desert.
Old Mar 30, 2011 | 01:08 PM
ivan_key's Avatar
Looks good if I let it sit for 20 mins, but give it about 10 mins running and it goes back down
Old Mar 30, 2011 | 01:17 PM
sscamaroburn02's Avatar
doesn't look low to me. Do you hear any strange noises like lifters etc??
Old Mar 30, 2011 | 01:22 PM
~ReapeR~'s Avatar
Anything over 15 or 20 psi at idle is fine. remember, its only spinning at 700 rpm or so. if the Oil pressure increases with rpm then i wouldnt worry. Its possible you could have a OPS malfuntion as well if your having problems.
ANTICOP RAM AIR's Avatar
How many miles on the oil change? Oil breaks down and thins out. Change the oil and filter, see what it does then, it should go way up.
Old Mar 30, 2011 | 01:36 PM
ivan_key's Avatar
Its due now, I'm at about 3000 miles on it and about 8 months old
Old Mar 30, 2011 | 01:38 PM
ivan_key's Avatar
Runs fine and doesn't make a sound, just heard bad things about 98 oil pumps and it would be a shame if I blew my motor before I have enough for the ls3
Old Mar 30, 2011 | 02:02 PM
trey1010's Avatar
thats what mine is usually at when the car is hot and idling, and i just put in a new ls6 oil pump.
Old Mar 30, 2011 | 02:13 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
That doesn't look too bad to me, considering the miles, year, and stock A4 idle rpms (that tach isn't totally accurate, if you have stock tuning then your idle speed is 550rpm in gear and 650rpm in P/N).
The same oil pump was used from '98-'00 in these cars. There is nothing that's specific to only '98s in terms of the oil pump. There were a small percentage that failed within those model years, mostly when they were still new-ish/low mileage. Often there was no warning sign, and the problem wasn't "low" oil pressure, it was a sudden case of ZERO oil pressure, due to the valve sticking.
The normal oil pressure readings in a '01-'02 car will usually be a bit higher, because they use the LS6 pump. This does not automatically mean that your pump is bad nor is it a required upgrade for the older cars, but it's one that many people do during a cam swap.
M6 cars will show a tad higher oil pressure in stock form as well, since their factory idle speed is higher (800rpm).
With a higher mileage engine like that, engine wear can also be a factor when it comes to oil pressure. Even if you change the pump, your readings may still not be exactly where a brand new LS1 engine would be.
Old Mar 30, 2011 | 02:17 PM
ivan_key's Avatar
Well then I guess I'm good, ill just change the oil pump out when I do the cam this summer
Old Mar 30, 2011 | 02:39 PM
fccs's Avatar
Your oil is fine. Oil pressure should be around 50-60psi COLD START. Once warmed up it will drop to around 30-40 area idle or slow driving. Your temp is kinda high though being a 98, might wanna check for head gasket leaks. 98 fbodies temps read different then the other years, the other years get around 210, the 98's don't unless your WOT or you got a leak somewhere.
When I say gasket leaks, I mean the very small spot they leak from in the back. All ls1's seem to get this when they get up in the miles, it isn't a big deal but when you do a cam swap id check it out
Old Mar 30, 2011 | 04:06 PM
ivan_key's Avatar
Ya I noticed my temp will get to 210 when at idle and just today it went a tad over 210, but as soon as I drive the car it goes back down to the 1/4 mark and doent go back up, thanks for everyones input on my oil pressure, I was hoping since it made it 127k miles with out a problem then it should hold up awhile longer
Old Mar 30, 2011 | 04:10 PM
ivan_key's Avatar
Alson thanks for the info on the oil pumps, I didn't know everything about them, I just want the motor to stay in good shape so I can sell the engine to help fund the new one going in at some point
Old Mar 30, 2011 | 04:39 PM
TurboStangJON's Avatar
The spec in the GM service manual is 6 psig @1000 rpms and that's minimum oil pressure - hot. The rest goes 18 psig @2000 and 24 psig @4000 so I think your well above fine.
