LS2 402 Cam Selection...Sponsers Please Chime in...
Ok...
Heres the deal...
Im searching for a Large streetable cam that would have good driveability & good street manners for my LS 402. My engine will have Patriot stage 3 227 cc heads with Large valve 4" bore combustion chambers.
Trying to make 450 - 500 H.P. at the Rear wheels if possible.
Please supply me with Lift, Duration at .050" lift, & LSA & Camshaft brand.
Any help would be appreciated.
Heres the deal...
well your better off contacting a sponsor and getting a custom cam spec'd specifically for you. especially, going off your sig with the 9" gearing, stall, and nitrous. just call some of them.
Thunder Racing also has some excellent cams for your build. I am doing a 402 as well and I am going with TR'
sTRoker V.3-247/251-.624/.632-112 lsa
I'm going for a bit more aggressive build but they have tons of options and I've had awesome results from their cams in the past.
The biggest issue with the diveability will be the tune and I would go with Mike at TR or Geoff at EPS for the tune. But like the others have said.... you need to call a shop and tell them your specifics and they will match a good cam or grind one for what you are looking for.
