Help with a connector/sensor
I changed over from a 5.3 to a 6.2.
A couple problems.. Under the intake the 5.3 had an extra sensor that the 6.2 does not have.. what is it?
The 5.3
![](http://i1098.photobucket.com/albums/g374/johnstarkweather1/IMG_0898.jpg)
The 6.2
![](http://i1098.photobucket.com/albums/g374/johnstarkweather1/IMG_0897.jpg)
The connector
![](http://i1098.photobucket.com/albums/g374/johnstarkweather1/IMG_0899.jpg)
Also on the front of the motor around the crank (Im guessing its the reluctor wheel). The 5.3 has a 3 pin connector and the 6.2 takes a 5 pin. Is this the difference between a 24x and 58x? Do I need to change over the wheel or is this something I can do by modify the wiring/programming?
The 6.2 motor with the 5.3 harness
The 5.3
The 6.2
The connector
![](http://i1098.photobucket.com/albums/g374/johnstarkweather1/IMG_0901.jpg)
I looked up the diagram on all data and found that eh L92 has a Camshaft actuator solenoid and the 5.3 does not. Im going to try and switch over the 5.3 sensor and harness to the L92 and see what happens but does anyone have any experience with this?
![](http://i1098.photobucket.com/albums/g374/johnstarkweather1/Escaladecamshaftdiagram.gif)
