how to check for cylinder misfire??
im curious on how you would check for this because i think im suffering from this problem. this t/a is pissing me off already. any help is greatly appreciated
LS1Tech Administrator
Received 1,803 Likes
If you can't get ahold of a scan tool you can unplug the plug wire to the cylinder that you suspect to be miss firing and if the rpm dip or it try's to die then it's atleast firing maybe not on time but it's firing. If there is no change when you unplug it then it's not firing
