Right headlight won't go down, help!
The left headlight goes up and down like a champ but the right one won't go down, the light works but I have no clue why it's stuck up or how to fix it. Help!
My TA did the same thing... The plug connector pins rusted out causing a bad connection... You will need to remove the entire headlight (if I rember correctly) to get to the connector, pretty easy.. Unplug the connector and look at the pins, probabbly rusted/corroded.. You can get new pins from the auto parts store/ radio shack or just cut the plug out and splice the wires together...
