General LSX Automobile Discussion Non-technical LSX related topics.
lq9 or ls2
Old 11-11-2011, 08:12 PM
Old School Heavy
speedtigger's Avatar
Originally Posted by zracer323
At that horsepower level, saying that aluminum will be less reliable than cast iron is not true. The debate between aluminum and iron is really only a weight issue until you are making 1000+ hp.
If you are willing to spend a little more money, the LS2 is the way to go IMO. 60-80 lbs at the front of the car is a big deal.
It is a weight issue and a cost issue. As far as the 80 pounds being a big deal. I would say that depends on what he is doing with the car. For handling I would say it is a very big deal. For drag racing it is nice, but there are cheaper ways to get 12 horsepower. Which is what it would take to make up for the 80 pounds.
Old 11-11-2011, 08:53 PM
second_2_none's Avatar
But 80lbs on the nose of the car is not the same as having 80lbs on the back of the car. It will make it harder for the nose to come up and transfer weight.
Another thing is the op said he is wanting a 408. You dont see many LS2 block 408's because of the water jackets being thinner and the aluminum block so it will overheat easier and not be as stong as a 408 iron block. Most of the time the 408's are iron blocks and the 402's are aluminum.
Old 11-11-2011, 09:50 PM
82cetuner's Avatar
your not ganna see a big difference in a 408 and 402 as far as horsepower is concerned anyways.
i would definetly go with the lighter weight 80 pounds is alot of weight its basicly like having 2 bags of concrete mix strapped to the front of your hood. and 80 pounds on the front will affect handling as well as weight transfer.
Old 11-12-2011, 11:34 AM
tony.m's Avatar
what does it cost to have a ls2 resleeved to a 402
Old 11-12-2011, 12:16 PM
m_liel's Avatar
Since the OP is looking to go 408 its an easy one for me. LQ all the way! I wouldnt go that big with an LS2, not without sleeving it. Especially with FI in the future. Just my .02!
Old 11-12-2011, 12:23 PM
SweetS10V8's Avatar
402 vs 408, same thing basically. Your splitting hairs, lol.
Old 11-12-2011, 12:43 PM
tony.m's Avatar
Does anyone know what it cost to have a ls2 resleeved
Old 11-12-2011, 01:20 PM
HoLLo's Avatar
I've never built either, but when it comes time to build a new motor, I'll definitely be going LS2 402. Aluminum blocks sound better too!
Old 11-13-2011, 04:27 AM
lemons12's Avatar
I made an assumption that with a question as such the op probably wasn't looking for 1000+rwhp.. And I wouldn't sweat a drop with an aluminum block at 1000rwhp.
408 and 402 would make within 5rwho of one another... If not closer.
Dont go with an lq9 for the heads.. They run a whopping 200$ or so on the boards all day.
Old 11-13-2011, 11:28 AM
jsmith564's Avatar
90% of us on here dont "race" enough to worry abt the added weight. Its like going to kroger and looking at mayfield milk for $5 and kroger for half that... unless you are big in racing save some $ and get the lq9.. thats basically what it boils down to.
Its all in what you want the car to do. If your goal is to goal is to road/drag race then get the lighter block. If you want a cool car, whip a few mustangs and show it off then get the other. you cant go wrong with either thats all im getting at.
Old 11-13-2011, 04:29 PM
lemons12's Avatar
Lol thats funny logic.. You aren't into racing enough to save 80#s for 500$ or so... But you are into enough to build a forced induction 408 with 750+rwhp. Kind of the same thing..?
You can build a 5.3 stock bottom on motor to whip a few mustangs, cruise around, etc.. Why would you need a 408 for that?
Old 11-13-2011, 06:06 PM
  #32
Old School Heavy
Most of what I have seen has been the "or so". LS2s and LS3s most everyplace I have looked are $800-$1000 more than their iron block counter-part. And used seems to be even more.
Old 11-13-2011, 07:18 PM
  #33
lemons12's Avatar
Since I spun a bearing I have been pricing many different engines. I have a source that I can get complete drop outs of about anything I want.
Similar miles an l76 will run roughly 450-650$ more than an lq9. Upside? It comes with a 500$ set of heads instead of a 200$ set. Not to mention the weight saving. The intake is also worth about 150$ more. So sell all that stuff to get down to a short block on both so you can add whatever heads and intake and you are looking at 50-200$ max between an iron and aluminum block.... Or so.
L76 is where its at... Aluminum block, add a 300$ ls3 intake and a cam and make 450+rwhp with an auto and 475+ with a manual. Can't beat it for the price..
Only downside.. You have to buy the 24x adapter and ls2 conversion kit... So add 350-450$ back on, still worth it imo.
Old 11-13-2011, 07:52 PM
  #34
spaulsen's Avatar
well, what im thinking is this. OP says he wants 700ish hp for now, but later plans on FI. the two setups will most likely be very differnt. so, is the issue money, which alot of you have been talking about, or is it best setup for reliability? alot of factors play a huge part in trying to decide which route to take. in my case i went with a lq block for reliability. im sure i can make up the difference in weight somewhere else. i think realistically OP just needs to figure out what he wants to do with this car, drag or street, then tell everyone and ask for suggestions. again, just my .02
Old 11-13-2011, 08:19 PM
  #35
lemons12's Avatar
Well with 408 cubic inches, he's not hitting 700 on motor, not even close.
Old 11-14-2011, 06:44 AM
  #36
Old School Heavy
I re-read all of the open poster's posts. I don't see anywhere were he told you enough about his planned combination for you to come to this conclusion. You also did not specify 700 crank or 700 RWHP. One can definitely make 700 crank HP with a 408.
Old 11-14-2011, 10:52 AM
  #37
jsmith564's Avatar
Fwit.. I got my lq9 complete with wiring no comp. For 1000 bones shipped by truck to my office. And a 3 month warr.
Old 11-14-2011, 11:38 AM
  #38
lemons12's Avatar
I always talk rwhp as the majority on here do.
The chances he will be making 700 from a 408 is slim to none.. It is an extremely safe assumption.
Old 11-14-2011, 12:21 PM
  #39
Old School Heavy
I paid $1150 for mine.
Old 11-14-2011, 12:22 PM
  #40
Old School Heavy
FI or N20 can make that happen.
Quick Reply: lq9 or ls2
