Question about inspection
Ok, I will try that. If I swap my motor out for a cammed 408 with a new computer, get it tuned, will everything work just fine? Reason I ask is I have been thinking about pulling the current cammed LS1 and using it and the computer in a different project. Was planning on buying a used PCM when I put the new motor in and getting it tuned. Should I expect any problems?
No reason why it shouldnt. As long as the tune is done right and everything is set up properly to pass. Ive inspected built 402s before and they passed with no problem. If its an obdII test then its all about codes. As long as the tune is set properly no reason you should have a problem
Well the owner of our dealership has a s2000 fully built with stage 3 honda racing parts and a pax supercharger and it passes inspection so i dont see why a turbo wouldnt but ive never inspected a turbo build car but i have inspected his s2k
