Intake filters
Intake filters
Just trying to figure out which filter setup flows the most clean air. Need to cram as much air as possible through a 4" intake pipe, coming in through a boxed front breather. N/A application so easier flow is better. Whichever is best, I'll be using the biggest filter I can.
We have the typical cone filter with a solid top. Can be used to on top of a velocity stack, just don't know if that's the best option.
Twin cone filters. Basically a typical cone filter with more filter surface area down in the top.
Wide (oval) cone filters
And finally the dual cone filter
.... copying to advanced tech section too.
