General LSX Automobile Discussion Non-technical LSX related topics.
new 99 SS owner...
Old 10-01-2012, 08:19 PM
SprChrgdGT's Avatar
Default new 99 SS owner...
A few months ago, I got rid of my 601rwhp supercharged mustang and since then, I've had an itch to get back at going fast. I built the mustangs motor, all blower install, etc so im pretty decent with some tools. Ive been doing TONS of research on the forum, google, youtube, etc... the car will be a 50/50 street/track car. I will drive it to the occasional baseball, softball, flag football game, or just whatever. I know "some" about the LSx motors but still learning... my goals for the car include a cam setup with a 150 shot with a nice suspension setup. Thats for now. Heads/intake setup may happen too but just trying to start off slow and in some direction. There seems to be alot of options on cams. For a 100-200 shot, I would assume just a good n/a cam will be the route to go. Any suggestions on that? I found some custom comp cams through searching but wanted to check and see if there were any suggestions.
What do you guys recommending changing with the cam install as far as chain, rods, springs, etc if anything. oil pump?
Old 10-01-2012, 08:24 PM
02 reaper z28's Avatar
if is a m-6 i would do this..
tsp torquer v-3 cam package witch encludes cam, pushrods, springs- $600
slp timing chain with gear, & oil pump-$350
4.10 gears
42lb injectors & ls6 intake
if is a A-4 i would add a 3600 stall & 3.73 gears
also i would stay away from nitrous oxide, i would be to scare for the tune, and there not all reliable. But it depends on experience i guess.
Old 10-01-2012, 08:37 PM
SprChrgdGT's Avatar
oh dang... yeah, meant to add its a 6 speed.
Old 10-02-2012, 06:32 PM
jsmith564's Avatar
you owned a mustang?
I'm sorry... now your on the right track!
Old 10-02-2012, 07:38 PM
A.R. Shale Targa's Avatar
This stick would work well w/100 shot and 4.10 gears.....if 150-200 squeeze
is preferred then perhaps widen the lobe separation a few degrees.
http://www.engpwrsys.com/index.php?a...d&productId=10
Old 10-04-2012, 01:33 AM
99Bluz28's Avatar
Do you care how high you have to spin it to get into the meat of the power band, DD friendly it is, or how aggressive the lobes are?
Quick Reply: new 99 SS owner...
