408 install....motor wont line up!!!!
LS1Tech Premium Sponsor
I assume you did use the alignment tool to ensure the disc and pilot bearing are lined up correctly? And you have the correct pilot bearing installed in the crank?
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic110569_2.gif)
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
http://www.coloradospeed.com/gm-roll...s6-p-5395.html
PLEASE tell me this is the right pilot bearing....i have a 4" Lunati crank that i bought from you guys that came with my 408 rotating assembly if that helps.....
