General LSX Automobile Discussion Non-technical LSX related topics.
LS2 crank same as LS3?
Old May 21, 2013 | 01:01 PM
samckitt's Avatar
Default LS2 crank same as LS3?
Are the cranks the same? Probably not, just curious.
Old May 24, 2013 | 11:38 AM
Fry_'s Avatar
Might not have the same balance, but pretty much all the 5.3, 5.7, 6.0, 6.2 cranks are basically the same, you just need to make sure your using the right crank sensor wheel.
Old May 25, 2013 | 12:40 PM
bww3588's Avatar
The ls3 ls2 and ls1 cranks are gun drilled. All the truck cranks are not. Other than that, with the exception of balance and reluctor tooth count, they are the same.
Old May 25, 2013 | 06:00 PM
Blackpanther99's Avatar
Agreed with both posts above^^ They are pretty much the same.
