General LSX Automobile Discussion Non-technical LSX related topics.
This ok jacking point?
Old May 29, 2013 | 01:18 PM
axlrose's Avatar
Default This ok jacking point?
Just making sure these are the right jacking points for my 2000 WS6. I know you can jack by the K member but my jack doesn't reach.
Front, behind drivers tire:
And Here is the rear in front of the driver rear
These places seem ok?
Old May 29, 2013 | 01:30 PM
BlackBetty99SS's Avatar
I would select the more inward point on the rear pic. You r dead on up front. Grab some pliers and bend the metal back down on the front where the fender meets. Looks like someone else tried using it for a jack point previously
Old May 29, 2013 | 01:50 PM
demonspeed's Avatar
It's not mine! woo hoo!
Front one is what I use. I use the longer oval (or the "lower" circle) for the rear.
Old May 29, 2013 | 03:14 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
All of those are fine.
And it does appear that your fender tab has been bent and could stand to be corrected.
Old Jun 7, 2013 | 09:21 PM
bmwman528e's Avatar
Front one is what I used as well when I had a WS6.
Old Jun 7, 2013 | 10:15 PM
chopperb's Avatar
That is where we lift from when we put the cars on a lift.
Old Jun 8, 2013 | 06:19 AM
Darker Shadow's Avatar
I agree with Chopperb - in the first picture using a 2 post lift I put front arms toward the front of your circle where it's wide and in the rear picture I'm pretty sure I either put the arm right underneath the rear control arm bolt or right next to it on your larger 2nd circle.
Old Jun 13, 2013 | 08:36 PM
bobyboy101's Avatar
That's where I lift mine in the front.
Old Jun 18, 2013 | 10:05 PM
86_irocz-28's Avatar
This or get sfc's and use them as a lift point
