Can I get some advice and/or help?!?
Hello there everyone I am new to this and I already know what I want to do to my truck but I don't know how to start or what to start with...
Here is a list of everything I would like to do, yeh yeh I know its a lot and probably not worth it but that's what I really want to do and I need to know the right way to do it.
`LT4 Hot Cam
`Roller Rockers
comp cams pro-magnums
`LS2 springs
comp 787-16 for std valves w/ 7 degree lock
`Pushrods
Chromemoly 5/16" or 3/8" outside diameter/ Trick flows
`Lifters
gm ls7 lifters
`Gaskets
front timing cover,optispark seal, crank seal, water pump drive seal, egr gaskets, throttle body, intake manifold, valve cover, water pump gaskets
`Timing chain- LT1 replacement chain
`Valve stem seals
`Optispark Distributor
`Whipple supercharger kit
`Cold air intake kit-K&N FIP kit
`Jet Preformance Programmer
Please don't tell me it will be a waist of my time and money all im looking for is helpful advice on what I should do or change in my list.
Thanks!!
`LT4 Hot Cam
`Roller Rockers
`LS2 springs
`Pushrods
`Lifters
gm ls7 lifters
`Gaskets
`Valve stem seals
Thanks!!
