Can I use the truck fuel rail on ls6 intake
I know I read it in one of the threads, that you could, but I also remember reading that you couldn't because of the TB or something like that. I also remember something to the effect that to use truck injectors with a LS1 fuel rails, you would have to use some kind of adapter or remove the plastic tips, but then you would need to get custom hold downs.
Another question...
Same as above, but LS1 to LS6. You can use the LS1 fuel rails and injectors with the Ls6 intake, right. I remember reading that the 00-02 injectors were 26lbs and the 97-98 were 28lbs, on the LS1 and Ls6 intakes, is this correct?
I just want to know what all I can swap over from a LQ9 intake to a LS6 or a LS1 to a LS6.
Sorry the info is all jumbled up, but I can't find the threads that I read before so I am going by what I half *** remember.
Another question...
