Non-Adjustable Panhard Bar Question
Hi,
This is probably a dumb question, but when installing a new non-adjustable panhard bar for my 02 z28 do I have to center it or will putting in the new panhard bar be to the exact specs of the factory bar and center the vehicle on its own?
Thanks for the response. So you just pop it in and go? Some people recommended getting an alignment done after the bar is installed...is this necessary?
LS1Tech Premium Sponsor
The benefit of a tubular non-adjustable panhard bar over the factory one is that it is substantially stronger which minimize the deflection in the bar itself.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
Hi,
So I didn't drive my z28 w/o the panhard bar, but in a sense, because after I installed the new UMI non-adjustable I took it for a test drive and it felt like it swayed/hopped more than w/the stock bar. The stupid thing I did was say screw the torque wrench, so I just tightened it with a socket wrench and took it for a quick 10min test drive to see if I noticed a difference and I did, but in a negative way. So, my question is, now that I didn't have it torqued tight enough while driving am I going to have to get an alignment, because I potentially threw things off?
Thanks!
Generally I never recommend using a non-adjustable panhard rod as there is limited benefits from them and more times than not people switch to an adjustable down the road anyways to be able to fine tune the rear end location.
You guys, thanks for the comments, but I think I screwed up the install. I posted a new question last night but dont seem to be getting a response. Can you please give me a quick answer?
Hi,
Thanks!
Hi,
Thanks!
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
In handling situations you can see some deflection in the factory panhard bar mainly due to the softer rubber bushings in them. Most of the issues with the factory panhard bar come from the rubber bushings but I have also seen people bend them and swear that they never hit anything. You have to remember that panhard bar really controls the side to side movement in the rear end.
A lot of people really get caught up on torque specs, you have to remember that you are just installing a panhard bar and not assembling a motor. As long as the bolts are tightened down and didn't come loose they are fine. The panhard bar has large bolts and can handle a good bit of torque so I generally just tighten them down as tight as I can. Were the bolts loose when you back and checked them after the test drive? There really should be no reason that you need to get an alignment.
Definitely, after you do that take a couple days to get some seat time and see what you think. The non-adjustable panhard bar is a super simple piece so it is very hard to mess it up. Also it should feel very similar as it did with stock panhard bar, maybe even a little more sure feeling in the rear of the car.
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
