Questions before I go cam only
Current Situation: Looking into doing an LS1 that's a cam only, full bolt on, weekender, with goals of making 420hp at the wheels.
I figure when I pull the cam, I might as well pull the heads and have them ported and polished. Are the gains from doing that enough to make it a priority over other bolt on that I could buy instead? Don't want to jump the gun on a h/c build if I don't have to.
Once I upgrade to an aggressive cam, ported heads, T56, Monster Clutch, I'd like my full bolt ons to include Fast 92 and matching TB. I believe the 92s will work with the stock fuel rails, but is there any advantage to upgrading fuel rails? Disadvantage from keeping stock fuel rails? If I kept the stock fuel rails, would I be able to keep the stock size injectors with my entire setup or would I need to get a higher # injector?
Thanks in advance.
Thanks in advance.
Your stock fuel rails are fine for the fast 92, and I would pick up a set of 42#ers Inj., you can find those for $100-125 used everywhere...as far as porting your stock heads, ive seen Advanced Induction get some killer numbers out of 241's. Good luck.
Not previously mentioned: Car will be M6 and suspension will be upgraded immediately.
Yes, LTs and full exhaust would be a part of the "full bolt ons".
I've also seen AI produce some top notch numbers with the 241s. My plan is to have Pat G spec out a cam and send the heads and cam to AI.
