Ls1/ls6 heads
Ok I am building my ls6 out of my 2001 camaro z28 auto car right now it is the stock ls6 block with stock bore and stroke and new rotating assembly and I have ported stock 241 cast heads with double valve springs and a comp cam 231 231 610 610 114° with the ls6 intake and exhaust and other bolt ons but now I am wanting more again so I want the biggest cc head and highest flowing heads I can fit on a 5.7L block I would love to do like ls3 heads but won't fit on my stock block car is getting a big turbo I've been looking at 225cc 64cc afr and trick flow heads but I'm am sure there is more I don't k now about.......
I haven't really set a number but a happy number I guess would be around 800 I guess thinking I'm going to go with either a 96mm or 106mm turbo so figured that should be on the low side to work it up from there
