About spark plugs
LS1Tech Administrator
Received 1,489 Likes
That link doesn't say not to use it, it just implies that its use isn't necessary on these plugs and that using it may alter torque values - therefore requiring additional caution when torquing plugs to avoid possible thread damage.
Originally Posted by NGK Spark Plugs
1. Anti-seize
NGK spark plugs feature what is known as trivalent plating. This silver-or-chrome colored finish on the threads is designed to provide corrosion resistance against moisture and chemicals. The coating also acts as a release agent during spark plug removal. NGK spark plugs are installed at the factory dry, without the use of anti-seize. NGK tech support has received a number of tech calls from installers who have over-tightened spark plugs because of the use of anti-seize. Anti-seize compound can act as a lubricant altering torque values up to 20 percent, increasing the risk of spark plug thread breakage.
