courtesy lights and rear hatch light on
Hello all, i am having a problem with the courtesy light and dome light. yesterday i saw that the power lock switch(driver side) button was not working as in was not clicking properly, as if the spring is loose so it would stay flimsy on either side(to open or close)so i assumed that the problem is the switch, i dismantled the door and disconnected the pin wiring harness for this particular switch and lights still stayed on, as i drove the car i saw that the rear hatch light came on and off, i assured that the hatch was closed and opened and closed it a few times but the light after that stayed on. the car when shut down locks the doors with the key fob and the lights still stay on for about 10-15mins.if i try to lock the door with the passenger switch, i get 2 chim sounds. should i check the rear hatch? or passenger door? or is this BCM problem?
any input would be appreciated
Have you checked the fuse?
