Rear end piece
So the cclips both went in with no problem but the gears around them seem to close together one guy told me to adjust the shims and it'll be fine.? I would need to pull the main caps off then pull the gears out.
The internals of a Torsen carrier were never considered to be serviceable/adjustable. Have you tried pulling the axles(with c-clips on) to reset the internals apart as they would be before the paddle was pulled out.
You still haven't stated why you had it apart. I've never heard of a re-insertion problem.
Changing gearset to 4.10 will create tooth/paddle interference.
Torsen Block Paddle
I had a badly squeak that i needed to fix before my road trip so I was just replaced the bearings a d seals, after I got to the point of reassembly I just went to put it back and it didn't fit so what's I ended up doing was pulling the diff out and pushed it backed once I got it out with my hands it was a very simple fix but to move it back its simple enough, it doesn't squeak anymore instead of using gear oil I packed it with a little high temp grease
