98-02 TA hoods & RPO codes
Why do some Trans-Am (98-02) Ram Air hoods have 4 intakes and others only have 2? Plus I have several RPO codes on my 99 TA I can't seem to decode such as, AAA,IL2,NF2,R7X,R9P,STE,VM3,V73,1SA,1OU,14I,142,6Z M,7ZM,8TJ,9TJ then on the bottom of the RPO tag it has BC/CC U 9567 followed by 142? Any help would be greatly appreciated!
The bc/cc is your paint code "base coat clear coat " the other rpo codes if u had a vin I could decode them at work. There might be a vin/rpo decoder online somewhere also.
https://www.google.com/url?sa=t&source=web&rct=j&url=https://www.marshu.com/images-website/car/gm-firebird-camaro-rpo-car-door-manufacturer-codes/gm-firebird-camaro-GM-RPO-car-codes.pdf&ved=0ahUKEwiLraeykabXAhWB4yYKHQKVCn4QFgh _MA4&usg=AOvVaw3ZPUWQjKcMYwHmSqLM3--D
LS1Tech Administrator
Received 1,685 Likes
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
AAA - Manual seat adjuster, 4-way
IL2 - Interior trim design
NF2 - Emissions system, Federal requirement Tier 1
R7X - Security package
R9P
STE - St. Therese, GM of Canada plant code
VM3 - Consumer information label
V73 - Statement of vehicle certification - US/Canada
1SA - Option group, Std. equipment
10U - Exterior color, Arctic White
14I - Interior trim, Gray
142 - Trim combination/seat trim, leather seating surfaces w/AQ9 seats (Trans Am) - Gray
6ZM - Front Spring
7ZM - Front Spring
8TJ - Rear Spring
9TJ - Rear Spring
R9P
6ZM - Front Spring
7ZM - Front Spring
8TJ - Rear Spring
9TJ - Rear Spring
As mentioned above, those are specifics regarding paint and interior color (Base coat/Clear coat, U 9567 color code, 142 = interior color and seat trim combo already decoded above.)
