Help 5.3 to 4.8 swap
I swaped my 5.3 engine out my 2002 Tahoe and put in a 4.8 from 2007 Tahoe I know the relucter wheel might be a problem but if they are the same which will be the 24x will it work and if they are different will it start and all I got to do is a flash the connectors are different so I swapped the cps also if I disconnect the neutral safety switch will it cause a no spark. I Know it don't crank
Restricted User
Eh, what?
If its a 24x, it'll drop right in, fire up like stock and run/drive.
If you got a 58x reluctor, its not going to run. You can't even flash the computer and make it run, its just not going to work.
Thank you sir for answering if I remove the relucter wheel from the old engine 5.3 will it fit on the new one 4.8 from the 2007 Tahoe or is there a adapter one they make
They aren't hard to change out but you need a special tool from Goodson to make sure it lines up properly. There are several threads on how to do it but I opted for the tool..
