Spend my money
Spend my money
Alright LS1Tech family, I've been pretty quiet the last 2 years due to work and focusing way too much on my Jeep. Anyways I live in the south east michigan area and it's time to show the Camaro some love and I would like some help choosing a direction for power. The car as it sits:
The budget: $7000 but I won't be doing any of this myself because I'm lazy/busy/taking the easy way out/living in an apartment for the next 11 months this time so subtract $2000 right off the bat and the budget is $5000
Goals: it's mostly a street car, occasional auto-x and maybe it'll see a drag strip, but most importantly I'd like something I can drive for 10 hours on the highway if I want. The car is by no means perfect, but it's the one I'm sticking with. So how would you spend my budget? Cheap engine swap? Rebuild the ls1? Heads + cam and be done? Or is my budget too small?
Picture of said vehicle:
- totally stock 1999 ls1 with 140k miles leaks oil a bit from almost every gasket
- t56 with a level 2 rebuild and monster level 2 clutch, upgraded hydraulics blah blah
- Midwest chassis FAB9 with a chinese truetrac (maybe good for 600whp)
- UMI coilovers, sways, more blah
We would love to help you with this project!
You can reach me though email at sgorecki@livernoismotorsports.com, or shoot me a PM here and we can go over the various paths possible.
It's an unfortunate limitation, but I'm not committed to doing an engine swap in the driveway of my apartment. That being said I hope that in a couple of years I'll start down the slippery slope of some extra air pressure. Am I leaving too much power on the table by running around 9.7:1 compression without boost?
I would do a setup like mine in my sig and drive the **** out of it. 450+ rwhp will get ya moving real good and you will have plenty of money left over to have a paint correction done and have your car ceramic coated
well given your budget I originally thought iron block stroker, but since you want auto cross potential id avoid adding the extra weight to the nose (thats the boat im in with my setup) sure you can make up for it but why bother if you dont have to? Ive debated dropping an ls3 in mine and putting the 414 in the Camaro, I came close to suggesting that but its a bit outside your suggested budget. I think you will be happy going LS2 and going lower compression is an odd trade on a NA setup. if you plan on boost yeah you are leaving something on the table, but if you need to do it in phases its more than fine, just know what to expect. It may feel sluggish compared to a higher compression but with a proper cam could yeild some great low end torque for a daily type car. thing to conisder though is what amount of boost you will run, you may not have to dip to low on the compression and end up with a setup that can do both pretty well.
im not particularly a fan of Livernois tuning process, but since your close to them your mileage may very. Good Luck!
out of the box the only thing I would site is the intake on a ls3 can pull great numbers but you could likely swap to rectangle portheads with the ls2 depending. Unless you have a specific power goal.....no not really.Swap wise neither is easier then the other as they both run a differnet relucter wheel than the ls1. I do think the ls2 can be run off the ls1 ecm with a few harness tweaks tough..If you are paying a shop for the work though neither of those matter.
so short answer other than the further potential of the ls3 cubes and top end options that are transferable ( i run l92 heads on my 414) id be content with the ls2. esecially after drivig one as a daily and had a c6 ls2 for a bit. On that lighter chassis you will notice that torque down low and will be astonished especially with the stroker. my 414 still scares the **** outta me. Nothing puts a smile on my face like the low end pull in the GTO and its got a good 400lbs on my f body
I notice you have a 4400 converter, is your TA a daily driver? How does it feel on the street?
Everyone always says a converter is one of the best mods for an auto, I need to get one at some point
To kind of answer your question, I absolutely would daily my setup. Is the converter loose..... absolutely, but it does not bother me. Imo 3.73's and a yank ss3600 drive pretty close to stock tightness wise until you go wot.
If ya want I can PM (don't want to post it here and get the op's thread off track) ya a video of it going wot from 80 mph
Thanks for the input!
Yeah, shoot me that video whenever you get the time
400ish rwhp freshen ls1, decent cam, LS6 intake, longtubes, powerbond UD pulley, tune. Loads of fun, very driveable
or 550 rwhp, 8k ish though, 414 stroker based on iron 6.0L or 6.2L aluminum shortblock. Summit LS3 cnc ported LS3 heads, cam, ported LS3 intake and big TB, long tubes, powerbond UD pulley, tune. Not quite as cheap on fuel, but this set up will enlighten anyone who partakes in a passenger seat experience wholly well. Plus it will roast almost any new car out there
Have fun
Have fun
Have fun
Have fun
