General LSX Automobile Discussion Non-technical LSX related topics.
Can it be done?
Old Jun 15, 2018 | 05:46 PM
Rich1374670x's Avatar
Default Can it be done?
I recently removed a lq4 out of a 2004 chevy express 3500. I did this without checking the mileage. Is it possible to install a battery and turn the key to get a odometer reading?
thanka
Old Jun 15, 2018 | 05:51 PM
01CamaroSSTx's Avatar
Did you get the ECM too?
Old Jun 15, 2018 | 05:53 PM
I have everything, but the 4l80e which I sold.
Old Jun 15, 2018 | 06:02 PM
I would think if you have the ECM it will report whatever the odometer reading is once wired up but I don't know this for certain.
Old Jun 15, 2018 | 06:08 PM
I am thinking about doing a carb swap. It is going into a 83 z28.
Old Jun 15, 2018 | 11:25 PM
Get it on the stand and run a compression and leak down test and if all is good then run it! If you have the time and money to go back through the engine that would be my recommendation.
Old Jun 16, 2018 | 11:45 AM
pantera_efi's Avatar
Default IGN-8 + Intake GMPP
Hi Rich, I can supply the IGN-8-LS Ignition and a GMPP Intake ?
Lance 949-250-1797
Old Jun 16, 2018 | 02:28 PM
01ssreda4's Avatar
Mileage is typically stored in the cluster. So the answer is no.
