Monitor Crankshaft bearing vibrations with Wireless sensors
Hi,
Bought new wireless sensor which help to check the vibration of electric machines, I started giving a try with one of home waterpump 3 phase motor and was able to check the readings by interfacing it with raspberry pi
But I am curious to know that will it be possible to monitor the crankshaft bearing vibration also ?
As I am not familiar with the what kind of vibration parameters we require to check the crankshaft bearing,
Also If someone worked or working on this kind of process then please share some helpful suggestion, as I am not much familiar to monitor the vibration of mechanical equipment like this
Thanks in advance .
Thanks in advance .
