Ls1 s10
You need to find the original part # stamping or at least what company they're from if aftermarket. If they're gm you can check the drivers front corner for a 3 digit number and that'll give you the basic info. If they're aftermarket then it gets tricky.
Been a while since I checked, but I remember procomp being questionable at best. Lots of quality issues and customer service was nonexistent. Maybe you have some of the better heads and got lucky. I don't know if even procomp could tell you though.
I'd try to contact procomp/speedmaster directly and see if they can get you any info. Just remember that their flow numbers are questionable so stick with just the basic info like valve size and such.
