Does AC compressor have a rating/Capacity? for engine swap
Im in the middle of doing an engine swap and wanted to retain the AC. To keep things simple I was just going to run the LS compressor and make the hose bracket fitting instead of making a bracket to bolt up the compressor that was in the car originally.
My question is, for those that have retain AC during an engine swap, does the compressor have any rating that I need to be concern about?
Or can they be mixed and match and still be comfortable cold during the summer?
Fixed output compressor versus variable output compressor. I was lucky that my 1999 GMC Sierra AC donor compressor was a fixed output compressor that was / is compatible with my Classic Auto Air AC system. No need for a different AC bracket and it fit nicely between my 70 El Camino frame rails.
What type of compressor do you have and what does the swap vehicle AC system need?
Rick
Rick
Rick
Rick
Based on what i found online I think they are both Variable output. Is there a way to distinguish them physically on mainly a spec type thing?
The way I see things, you have already determined they are both variable output. Why ponder the deeper questions of what they look like? I'd move on to solving the bracket problem and what changes need to be made within the operating system of your PCM to support the Audi air conditioning system.
Rick
Rick
