Pcv
New to the LS platform. We ave an '07 L33 with an LS6 manifold going into a 96 S10. It's my understanding that the pcv is built into the drivers valve cover. Does the hose for that also connect to the tube on the passenger side valve cover? I'm trying to figure out the catch can hose routing.
Of course...pics are always a bonus...lol
Thanks.
Thanks.
I'm assuming you have tubes on both valve covers, one at the back on the driver side and one at the front on the passenger side. What I would do is run a line from the driver valve cover around the back side of the intake and run it up to the front of the passenger cylinder head, through the input port of the catch can and then run a line from the outlet port of the catch can through an inline PCV valve and then to the intake manifold port which is on the passenger side up front. For the passenger valve cover run a line from it to the port on the throttle body if it has one or you will have to tap into the intake tube between the filter and the throttle body.
