Help Picking and Intake
The Truck:
- 2004 Silverado Z71 Crew Cab 1500
- 408 stroker
- LS3 heads
- Compression ~10.5:1
- Cam specs:
- Lobe Separation - 115.2
- Valve overlap - .5
- Intake
- Centerline - 113.2
- Duration - 226
- Lift - .61193
- Exhaust
- Centerline - 117.2
- Duration - 234.4
- Lift - .59533
- 4L80E transmission
- 2,400 stall
- Texas Speed stainless steel headers and full 3" exhaust
- Currently has L92 truck intake and the factory 5.3 throttle body
- Used for daily driver and pulling a trailer
For the cost of the FAST around $900 plus fuel rails it's not worth the 8hp & 1ft/lb of torque on the LS3. Your 408 will show more gains with the fast intake but with your mild camshaft choice... probably not enough to justify the price IMO. What does your research and the "conflicting information" show? I'm sure there are more knowledgeable stroker rec port members here than me.
On the other hand, my tuner is telling me, based on what he's seeing with AFR etc., the truck needs the biggest intake and TB I can get. I'm considering just throwing a 92MM TB on it and seeing what he thinks after that.
