I need info!!! ASAP!!!!
I have a Lsx bowtie block, The crank shaft I have is a 24x wheel…. Can I still run a 24x wheel in a lsx block and just mount the 24x sensor up front???
Im about to start assembling, and I need to know
thanks fellas!
thanks fellas!
^^^This^^^
No change to crank sensor location but no rear cam sensor location so you'll need the harness extension and run the front cover with cam sensor. You'll also have to clearance the cover if running a double roller timing chain.
