Battery disconnected and have question
Hi, I have a 02 WS6. I disconnect the battery and later when I hooked it back up and started the car. It ran rough and did not want to idle. I let it run for a few minutes with foot on the gas. Turned it off and restarted and then the idle seemed ok. Is this normal after the battery was disconnected? Is there some procedure I should have followed when I hooked to battery back up?
Thank you
Joe
Thank you
Joe
Totally normal!
Anytime you disconnect the battery for a period of time the ECM will have to run through its systems checks and it will run rough at first.
The following users liked this post:
NC01TA (08-16-2021)
LS1Tech Administrator
Received 1,726 Likes
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Yes, this is totally normal. There is an idle relearn procedure that can be done, but as you have discovered it will eventually relearn on its own.
