Ls block engine mount locations
Do all LS blocks have the same engine mount location? Exhaust port location? Like is the LS1 the same as LS7? For mock up purposes I might use a junk engine is what is driving the ?
Thanks
Thanks
Yes. All LS engines use the same mounts/locations. Exhaust port locations are the same, sizes and shapes differ depending on type, but the location is physically the same.
From a 327 to 454 all with the same size external dimension LS block. One of those big things in a little package deal depending on what foundation you choose to go with.
What you're asking is how to re-purpose an aluminum LS that chunked a rod through the block or otherwise broken to the point of non-rebuildable.
