AC issues
Good luck with your troubleshooting. I'm pretty clueless about theses things.
230psi is also a "good system pressure while running. When the system is off (not running) the low and high side pressures will equalize. Making the pressure switch "see" above 35psi to allow the compressor circuit to energize.
Yesterday it worked briefly then the clutch disengaged. Back to the drawing board.
