No starter action just a click
I have 2 new starters even a power xs racing starter. None will spin on the car just a click.
1999 6 speed ss.
I can turn the crank bolt and the flywheel turns with ease.
I swapped the wires checked and changed the fuses and relay.
new battery with the booster on it.
Just a faint click.
The starter doesnt move at all i dropped it down grounded it and tried to cra k it. Nothing happened.
1999 6 speed ss.
Just a faint click.
Bad connection somewhere. Start with the battery cables. Remove both from the batt, clean both the cable ends and the terminals of the batt with a brass brush and baking soda & hot water until every metal surface that makes any kind of contact is clean and shiny, reinstall, and tighten to maybe 6 ft-lbs or so.
1999 6 speed ss.
Just a faint click.
1999 6 speed ss.
Just a faint click.
