loading a Z28 on a trailer
I am looking at possibly traveling this next week to look at/buy a camaro. Is there enough ground clearance to drive it onto say, a U-haul trailer without scraping, or hitting the nose on the ramps? Thanks.
IF...you decide and or find out the available ramps are too short and provide too steep of an angle you can (very carefully) place a second set of boards/ramps on the first pair where the tops of the second ramps lie on the middle of the first ones. Kinda two stage it. it provides a more gradual slope but this can be unstable if the boards are not thick enough or too narrow.
on a nother note you can back the trailer up too a steep slope/hill or a ditch and use the ramps to brigde any gap not closable. the angle should be fairly shallow. hope this helps, if I convied this in a confusing manner let me know and I may able to clarify a little. good luck.
Ive used the Uhal dual tandem trailer to move my car, I had some problems with my X-pipe getting caught up when I was off loading it(eibach pro-kit), but just lowering the landing gear down and raising the nose of the trailer fixed it, and the nose of my car didnt rub or anything when I was putting it on or taking it off. Hope this helps!!
1 Post
There are several options in my area. I've used a couple of them.
Call around to all the rental places within 20 miles and find out what car carriers are available. Go look at them. Make sure you have a big enough truck to pull the car/trailer combo out of any contortions you may make while loading (ditches, etc.)
The place I go to has an aluminum car carrier that provides a tilt option. They also have a big flatbed with ramps that was a close fit, but worked pretty good.
Don't forget to check all your light connections, and ensure you have the correct size ball and hitch in advance. You don't want any suprises when you arrive to hook up!
It may help to air the car's tires up extra to give a smidge more clearance, so an air tank may be nice to have.
