General LSX Automobile Discussion Non-technical LSX related topics.
Next mod ?
Old Aug 30, 2006 | 04:47 AM
DaGeneral's Avatar
Default Next mod ?
I have 400 bucks to spend on my car right now and I was wondering what mod/mods I should do to my car. My current mods are in my sig, I also have a Pro 5.0 shifter...
I was thinking of possibly going with 410 gears, I can get them installed and running for about 380 bucks, but I would need to get the speedo calibrated. How much will that run me? Ive had my car dyno-tuned before...
I dont really want nitrous, so I was thinking of possibly an LS6 intake or an aftermarket throttlebody, but Im hesitant to add any of it until I go big with H/C in the future...
Will gears be the best way to go?
Old Aug 30, 2006 | 04:57 AM
300bhp/ton's Avatar
Depends really on what you want from the car and what you use it for.
The rear end is pretty weak on the Fbody and easily broken with a M6 car, most upgrade for a 12 bolt of a 9". So gears may be fun and will make a difference to performance but you'll run the risk of producing a bigger cost in the future.
Apart from that there are so many mods out there:
-induction
-suspension
-chassis
-brakes
-power adder
A Ls6 intake and a stock ported TB should make a difference and should be within budget. Apart from that the next option would be a FAST 90/90 setup but that'll be more money.
Chassis and suspension mods may be well worth it, they won't add HP but they'll tighen up the car in the corners and will be well worth the investment once you start upping the HP.
Old Aug 30, 2006 | 05:41 AM
Reject's Avatar
i'd do the suspension upgrades first. dosnt mean **** if you have XXX amount of hp and cant land any of it to the ground.
Old Aug 30, 2006 | 12:52 PM
bjamick's Avatar
invest in some drag radials and some gear.. just .02
Old Aug 30, 2006 | 01:48 PM
DaGeneral's Avatar
Hmmm, I am running on drag radials right now. I really dont plan on going huge with H/C just yet, this is my daily driver and until I find another car and save up some money(which is almost impossible as you can tell) then I have to keep this car as reliable as possible.
I think I will end up going with 410's though..
Old Aug 30, 2006 | 01:50 PM
bjamick's Avatar
in that case i would go with a ls6 intake and get your stock TB ported. 25 hp
Old Aug 30, 2006 | 01:54 PM
DaGeneral's Avatar
I'm skeptic as to whether I can gain 25 HP to the rear wheels, and also, I dont want to do something like that yet, because it will most likely affect my tune. With the gears I would just have to calibrate the speedometer...
Old Aug 30, 2006 | 02:29 PM
jpat1023's Avatar
I would either do the gears or some suspension work...do you not have sfc??
